01-25-2007 05:59 AM
01-29-2007 10:16 AM
01-29-2007 06:21 PM
From VISA library, you can control the device with through ASRLx::INSTR resource, where the "x" specifies the actual COM port#. For example, if using COM4 port, you can use ASRL4::INSTR to open a VISA session by LabVIEW's VISA Open function.
If you want to map your device to a specific COM port#, you can assign it at the Windows Device Manager. Launch Device Manager, open the "Ports (COM & LPT)" tree then right-click on your USB device name to show its Property. In the "Port Settings" tab, click the "Adavanced..." button then you can assign any COM port# you want.
01-30-2007 06:06 AM
01-30-2007 06:38 AM
