01-20-2013 01:36 AM - edited 01-20-2013 01:58 AM
Sir,
I am a beginner in Labview and Urgently I need a labview program for keithley 2001 scan card for thermocouple temperature measurement with GPIB interface and keithley 2000 DMM..
Any body please help me...
Thanks in advance
shan.....
01-20-2013 02:29 AM
Did you do the simple task of going to Help>Find Instrument Drivers? Once you log in, specify Keithley and 2000, then download the driver. There will be an example (Help>Find Examples). The main instrument driver network has links on how to use a driver.
01-20-2013 08:15 AM - edited 01-20-2013 08:20 AM
thank you sir ..
I have got driver for keithley 2000 from NI Web ,but the program doesn't show reading in temperature unit.Instead of temperature, it is showing voltage reading only. can you help me to convert multi channel thermocouple voltage to curresponding temperature..
Please refer my attachment..
shan...
01-20-2013 09:05 AM
01-20-2013 11:35 AM
thank you for your answer...but still there is a problem to read temperature of all channels simultaneously in temperature unit..
can u help...
is there any polynomial equation for thermocouple voltage to temperature conversion???
please help me...
shan...
01-20-2013 11:40 AM
01-20-2013 11:46 AM
can i use DAQmx for Keithley 2000 and 2001 scan card with GPIB Interface???
01-20-2013 02:27 PM
