Tektronix TBS1062 goes to default set up
I am a newbie to IVI programming.
I am currently configuring the Basic, Channels and Trigger settings on the IVI Scope step and everytime I configure the scope goes to a default set up.
Am i missing any step configuration or initialization??
please help.
Thank you
(4,849 Views)
The Initialize code will usually have a *RST in it, which will reset the scope.  You'll need to dig into the code to find out for sure.
(4,843 Views)
Hi there,
As crossrulz has said, your problem could be with the reset in the Initialize step. The default for the reset device input is True as you can see below:
If you search the LabVIEW example finder (Help>Find Examples) for "IVI" you may find some code to help you when you are getting started. If you are still having problems, feel free to reply with your code attached and I can take a look at it for you.
Maria McKavanagh
FSE West London & Surrey
National Instruments UK & Ireland
(4,818 Views)
Thank you very much for the response. I understood that the reset function is called everytime I configure.
Therefore I am configuring the scope everytime I need to take a measurement. It works that way.
(4,815 Views)
