01-21-2009 12:40 PM - edited 01-21-2009 12:43 PM
Hi everyone,
I'm attempting to make fast voltage vs. time measurements on a voltmeter. The measurements have to have a frequency of 10 - 20 ms to be meaningful to me. I'm simply using a Keithley 2000 Multimeter instrument driver to take multiple measurements, so it does no additional calculations other than recording data. However, I noticed that there is an inherent delay in every measurement of about 3 ms, and this builds up to a significant delay when I get to hundreds of measurements. I looked at the Keithley datasheet, and they claim to be able to take about 2000 measurements every second, so I don't believe that the problem is the instrument, but rather the built in delay of LabView.
Is there anything I can do about this delay, or will I simply have to correct for it when we get the data?
Matt
01-21-2009 02:38 PM
01-22-2009 09:22 AM
Readings/second is based on how many digits of resolution the meter is set to, suggest you review the manual.
-Ak2DM
01-23-2009 12:01 AM
