11-18-2002 12:11 PM
11-20-2002
03:56 PM
- last edited on
11-10-2025
04:01 PM
by
Content Cleaner
Are you using the IVI driver or the traditional driver? Both are available on our website. What is the error code and error message? Is this an error sent from device or an error generated in the NI Software? If it is from the NI Software obtain an NI Spy capture of it and a post it to the thread.
NI Spy Tutorial
Ray K
NI Application Engineer
11-20-2002 04:51 PM
11-21-2002 07:40 PM
11-22-2002 01:16 PM
11-22-2002 07:31 PM
11-27-2002
02:45 PM
- last edited on
11-10-2025
04:01 PM
by
Content Cleaner
Sorry it took so long to get back to you, we were short staffed last week and I was swamped with support emails. If you are still interested in automation, the following information would be very helpful to you. All instrument drivers required an initialize VIs first, followed by any programming, and a close vi at the end. Note that is the structure of the Getting Started VI that is included with every driver. It does not sound like you are always calling the Initialize VI first.
It looks like the NI-Spy Tutorial is under periodic review.
Getting NI-Spy captures of both your program and the WaveStar program will enable you to seen the differences bet
ween the communications.
Ray K
Note: If you want to print NI-Spy capture, export it to a spreadsheet file and use the following example program to reparse it into a spreadsheet format first.
11-27-2002 03:21 PM
