TDK Lambda GEN 150-10
Hi All
I have a TDK Lambda power supply unit and would like to control it using Lab View 17. I see that the VI instrument drives for this hardware from NI does not support Ethernet interface for this unit only IEEE, serial and USB interfaces.
I need to use LAN connection. Do I add a switch as a middle man between my PC and the power supply units or can I use a LAN to USB adapter cable and then use the USB VI drivers?
I am new to Lab view so do mind the silly question and help is much appreciated.
(2,670 Views)
According to the manual http://www.us.tdk-lambda.com/hp/pdfs/Product_manuals/83034100.pdf, you should be able to connect through TCP then send and receive typical SCPI commands/queries.  LabVIEW is well suited for this.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,646 Views)
