02-02-2001 09:00 AM
01-24-2002 10:15 AM
09-14-2022 02:30 PM
I have two TDK-Lambda G40-85 Power Supplies in my system, they are setup as IP Addresses 192.168.10.10 & 192.168.20.20 respectively. When I launch the Open VISA Test Panel from MAX for the one with resource name of TCPIP0::192.168.10.10::inst0::INSTR, everything works just fine, but when I run the Initialize.vi in LabVIEW I get error code -1073807339 (VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.)
ANy ideas about what may be going on here?
09-14-2022 06:15 PM
Are you trying to initialize with the VISA Test Panel open?
09-16-2022 09:31 AM
No, but for some reason these PS's (TDK-Lambda G40-85) create two resource allocations in MAX, one for SOCKET and one for INSTR, whereas a different system I am using a TDK-Lambda GSP-1000 (which is the same family of GENESYS+ Power Supplies) it only creates the INSTR resource allocation in MAX, and is working with my driver no issue.
