02-20-2019 04:21 PM
I already checked the termination character, and I believe it's correct (0x0A, \n), please check the screenshots below, command buffer in NI I/O Trace shows exactly the same command in both cases. Before typing the sting constant for the VISA Write, I changed from "Normal Display" to "'\' Codes Display", which should properly interpret the \n as the New Line character. I also tried the 0x0D (Carriage Return), but it did not work either.
Tek7854-GPIB-NI-MAX
Tek7854-GPIB-LabVIEW-VI
02-21-2019 02:55 AM
Is your NI-MAX a 32-bit or 64-bit executable? It's 32-bit if it's under C:\Program File (x86).
On my computer NI-MAX is a 32-bit executable, and LabView is 64-bit. Therefore, they aren't linking to the same NI-VISA library. It could be that NI-MAX is using an older/different version of NI-VISA than LabView.
Confusingly, 64-bit DLLs are in C:\Windows\System32 and 32-bit DLLs are in C:\Windows\SysWOW64. You can look in either directory for visa32.dll , or even visa64.dll.
02-21-2019 12:24 PM - edited 02-21-2019 12:25 PM
Thanks Bitdiddle, you pushed me in the right direction and I fixed the problem, I was using x64 LabVIEW, by switching to x86 version it started working. In short: Agilent USB-GPIB adapter I'm using works thru NI VISA Passport for Tulip which is 32bit (x86) exclusively, therefore x86 LabVIEW is required so that it calls x86 NI VISA. I suppose x64 LabVIEW cannot use x86 NI VISA. I'm just a bit annoyed by the fact that it "almost" worked with x64 LabVIEW (the instrument was certainly getting the command), I expected that x86/x64 conflict would yield a straightforward full stop error like "cannot load library..." or so.
My NI-MAX is x86, and with your hint I figured out what was going on. I also found this thread:
dealing with a similar situation.
VISA deployment is...strange. I have both Agilent and NI VISA on my system (NI VISA as primary):
not sure which is which here, will leave it alone now since it seems to work.
Just hope that this experience helps the OP as well.
