02-20-2019 11:45 AM
There is a similar post...but mine is freezing at silverlight, also at 0%. I tried installing keysight IO, suggested in that similar post, but not work. I tried both NIVISA 18.5 and 17.0...neither worked.
Below is install log (cannot upload files here).
<?xml version="1.0" encoding="UTF-16" standalone="no" ?>
<installDetails version="1.0">
<nidist.id>
<VolumeId>
<DistributionGUID>{FFD051CC-1C3B-4155-9A46-C1B3D7BED5D6}</DistributionGUID>
<DistPackageGUID>{C45F11B7-0B3C-454D-9B5C-FA3F5FC4E35C}</DistPackageGUID>
<DistributionVersion>18.5.0.30</DistributionVersion>
<DistributionType>Driver</DistributionType>
<DistributionLanguage>9,17</DistributionLanguage>
<Volume>1</Volume>
<ExePath>setup.exe</ExePath>
<UpdateInfoFile>SupportFiles\updateInfo.xml</UpdateInfoFile>
</VolumeId>
</nidist.id>
<timeStamps>
<start>Wed Feb 20 09:19:35 2019</start>
<initializationEnd>Wed Feb 20 09:19:40 2019</initializationEnd>
</timeStamps>
<path>C:\National Instruments Downloads\NI-VISA\18.5\</path>
<distributionType>NI</distributionType>
<launchedBy>User</launchedBy>
<features>
<feature key="activex.NI.ACTIVEX.2017" name="NI ActiveX Container">
<oldState>absent</oldState>
<newState>local</newState>
</feature>
<feature key="ActiveX_MSM.NI.ACTIVEX.2017" name="NI ActiveX Container MSM">
</feature>
<feature key="activex64.NI.ACTIVEX64.2017" name="NI ActiveX Container (64-bit)">
</feature>
<feature key="LLDRVO.CVI1700.LLDO" name="LabWindows/CVI Low-Level Driver (Original)">
</feature>
<feature key="LLDRVU.CVI1700.LLDU" name="LabWindows/CVI Low-Level Driver (Updated)">
</feature>
<feature key="HelpAsst.HELPASST101" name="NI Help Assistant">
</feature>
<feature key="HelpAsst64.HELPASST64101" name="NI Help Assistant (64bit)">
</feature>
<feature key="lvrt_DEP.LVRT.DEP.2018" name="NI LabVIEW 2018 Deployment Framework">
</feature>
<feature key="ni_error.NI.ERROR.REP.2018" name="NI Error Reporting 2018">
</feature>
<feature key="LVRT_ErrDialog.LVRT.ERRDLG.2017" name="NI LabVIEW 2017 SP1 Real-Time Error Dialog">
</feature>
<feature key="LVRT_NBFifo.LVRT.NBFIFO.2017" name="NI LabVIEW 2017 Real-Time NBFifo">
</feature>
<feature key="LVRTE.LV.RTE2017" name="NI LabVIEW Runtime 2017 SP1 f3">
</feature>
<feature key="Netscape7Plugin1.LV.RTE2017" name="Netscape 7 Plugin 1">
</feature>
<feature key="Netscape7Plugin2.LV.RTE2017" name="Netscape 7 Plugin 2">
</feature>
<feature key="FireFox.LV.RTE2017" name="FireFox Plugin">
</feature>
<feature key="Netscape6Plugin.LV.RTE2017" name="Netscape 6 Plugin">
</feature>
<feature key="PortIO.LV.RTE2017" name="Support for In Port or Out Port VIs">
</feature>
<feature key="Chrome.LV.RTE2017" name="Google Chrome Plugin">
</feature>
<feature key="IEPlugin.LV.RTE2017" name="Internet Explorer Plugin">
</feature>
<feature key="MozillaPlugin.LV.RTE2017" name="Mozilla Plugin">
</feature>
<feature key="DotNetAssemblies.LV.RTEDNET2017" name=".Net Assemblies">
</feature>
<feature key="LVRTEres.LV.RTER2017" name="NI LabVIEW Runtime 2017 SP1 Non-English Support.">
</feature>
<feature key="SysStatePub.LV.SYSPUB.2017" name="NI System State Publisher">
</feature>
<feature key="SysStatePub64.LV.SYS64.2017" name="NI System State Publisher (64-bit)">
</feature>
<feature key="WebServerLVRTE.LV.WSRVRRTE.2017" name="NI LabVIEW 2017 Run-Time Engine Web Server">
</feature>
<feature key="MDF_Support.MIFMDFS" name="MDF Support">
</feature>
<feature key="MKL.LV.MKL2017" name="Math Kernel Libraries">
</feature>
<feature key="MKL64.LV64.MKL2017" name="Math Kernel Libraries (64-bit)">
</feature>
<feature key="MetaUtilsFeature.METAUTILS" name="MetaUtilsSupport">
</feature>
<feature key="MetaUtils64Feature.METAUTILS64" name="MetaUtilsDLL">
</feature>
<feature key="MS_CW3DG.MSCW3DG" name="ActiveX 3D Graph Control">
</feature>
<feature key="MS_CW3DG_Redist.MSCW3DG" name="ActiveX 3D Graph Redistribution Merge Modules">
</feature>
<feature key="MSCommonRuntime.MS.CMNRT400" name="Measurement Studio Common Runtime 17.5 for .NET Framework 4.0">
</feature>
<feature key="MSCommonRuntime_Rdst.MS.CMNRT400" name="Measurement Studio Common Redistribution Merge Modules">
</feature>
<feature key="MXS.MXS00" name="MXS">
</feature>
<feature key="MXS64.MXS64" name="MXS64">
</feature>
<feature key="MetaSuite.METASUITE" name="MetaSuite">
</feature>
<feature key="NIAPAL.NIAPAL1850" name="NI-APAL 18.5 Error Files">
</feature>
<feature key="NIAPAL64.NIAPAL641850" name="NI-APAL 18.5 64-Bit Error Files">
</feature>
<feature key="CabledPCIe.CABLEDPCIE" name="NI-Cabled PCIe 17.3">
</feature>
<feature key="CabledPCIe64.CABLEDPCIE64" name="NI-Cabled PCIe 17.3 64-bit">
</feature>
<feature key="NIDIM.NIDIM" name="NI-DIM">
</feature>
<feature key="NIDIM64.NIDIM64" name="NI-DIM Support for 64 Bit Windows">
</feature>
<feature key="NIMDBG.NIMDBG32" name="NI-MDBG">
</feature>
<feature key="NIMDBG64.NIMDBG64" name="NI-MDBG Support for 64 Bit Windows">
</feature>
<feature key="NIMRU.NIMRU" name="NI-MRU">
</feature>
<feature key="NIMRU64.NIMRU64" name="NI-MRU Support for 64 Bit Windows">
</feature>
<feature key="NIMXDF.NIMXDF32" name="NI-MXDF">
</feature>
<feature key="NIMXDF64.NIMXDF64" name="NI-MXDF Support for 64 Bit Windows">
</feature>
<feature key="NIORB.NIORB" name="NI-ORB">
</feature>
<feature key="NIORB64.NIORB64" name="NI-ORB Support for 64-bit Windows">
</feature>
<feature key="NIPAL.NIPAL" name="NI-PAL">
</feature>
<feature key="NIPAL64.NIPAL64" name="NI-PAL Support for 64 Bit Windows">
</feature>
<feature key="NIPALERR.NIPALERR" name="NI-PAL 18.5 Error Files">
</feature>
<feature key="NIPAL64ERR.NIPAL64ERR" name="NI-PAL 18.5 64-Bit Error Files">
</feature>
<feature key="PCIBRD.PCIBRD" name="NI-PCI Bridge Driver 18.5">
</feature>
<feature key="PCIBRD64.PCIBRD64" name="NI-PCI Bridge Driver 18.5 64-bit">
</feature>
<feature key="NIQPXI.PXIQ32" name="NI-QPXI">
</feature>
<feature key="NIQPXI.PXIQ64" name="NI-QPXI for 64 Bit Windows">
</feature>
<feature key="NIROCOErr.NIROCOERR32" name="NI-RoCo Error Files">
</feature>
<feature key="NIROCOErr.NIROCOERR64" name="NI-ROCO Error Files for 64 Bit Windows">
</feature>
<feature key="NIRPC.NIRPC" name="NI-RPC">
</feature>
<feature key="NIRPC64.NIRPC64" name="NI-RPC Support for 64 Bit Windows">
</feature>
<feature key="NIRPCRT.NIRPCRT" name="NI-RPC for Phar Lap ETS">
</feature>
<feature key="NIRoCo.NIROCO32" name="NI-RoCo (32-bit)">
</feature>
<feature key="NIRoCo.NIROCO64" name="NI-RoCo (64-bit)">
</feature>
<feature key="Development_Common_64.VSADS64" name="NI-VISA x64 Development Support">
</feature>
<feature key="Documentation.VSADOCS" name="NI-VISA Documentation">
</feature>
<feature key="Documentation64.VSADOC64" name="NI-VISA Documentation 64-bit">
</feature>
<feature key="VISADotNet64.VSDND641750" name=".NET 4.0 - 4.5.1 Development Support 64-bit (IVI)">
</feature>
<feature key="Error.VSAERR" name="NI-VISA Errors">
</feature>
<feature key="Error.VSAERR64" name="NI-VISA Errors 64-bit">
</feature>
<feature key="VisaHeaders.VSAHDR" name="NI-VISA Headers 18.5.0">
</feature>
<feature key="VisaHeaders.VSAH64" name="NI-VISA Headers 64-bit 18.5.0">
</feature>
<feature key="VISAIC64.VSAIC64" name="NI-VISA Interactive Control 64-bit Support">
</feature>
<feature key="ENET_Passport.VSAENET" name="NI-VISA ENET Passport (32-Bit)">
</feature>
<feature key="ENET_Passport64.VSAENET64" name="NI-VISA ENET Passport (64-Bit)">
</feature>
<feature key="Enet_Serial.VSAENAS" name="NI-VISA ENET-Serial Passport (32-Bit)">
</feature>
<feature key="EnetASRL_x64_Support.VSAENAS64" name="NI-VISA ENET Serial Passport (64-Bit)">
</feature>
<feature key="GPIB_Passport.VSAGPIB" name="NI-VISA GPIB Passport (32-Bit)">
</feature>
<feature key="GPIB_Passport64.VSAGPIB64" name="NI-VISA GPIB Passport (64-Bit)">
</feature>
<feature key="PXI_Passport.VSAPXI" name="NI-VISA PXI Passport (32-Bit)">
</feature>
<feature key="PXI_Passport64.VSAPXI64" name="NI-VISA PXI Passport (64-Bit)">
</feature>
<feature key="Remote_Passport.VSAREMOTE" name="NI-VISA Remote Passport (32-Bit)">
</feature>
<feature key="Remote_Passport64.VSAREMOTE64" name="NI-VISA Remote Passport (64-Bit)">
</feature>
<feature key="Serial_Passport.VSASER" name="NI-VISA Serial Passport (32-Bit)">
</feature>
<feature key="Serial_Passport64.VSASER64" name="NI-VISA Serial Passport (64-Bit)">
</feature>
<feature key="Tulip_Passport.VSATULIP" name="NI-VISA Tulip Passport (32-Bit)">
</feature>
<feature key="USB_Passport.VSAUSB" name="NI-VISA USB Passport (32-Bit)">
</feature>
<feature key="USB_Passport64.VSAUSB64" name="NI-VISA USB Passport (64-Bit)">
</feature>
<feature key="GPIB_x64_Support.VSAR64" name="GPIB x64 Support">
</feature>
<feature key="PXI_x64_support.VSAR64" name="PXI x64 support">
</feature>
<feature key="Remote_x64_support.VSAR64" name="Remote x64 Support">
</feature>
<feature key="Serial_x64_support.VSAR64" name="Serial x64 Support">
</feature>
<feature key="USB_x64_Support.VSAR64" name="USB x64 Support">
</feature>
<feature key="Core_x64_support.VSAR64" name="NI-VISA x64 Runtime Support">
</feature>
<feature key="COM_x64_Support.VSAR64" name="COM x64 Support">
</feature>
<feature key="Enet_x64_Support.VSAR64" name="ENET x64 Support">
</feature>
<feature key="EnetASRL_x64_Support.VSAR64" name="ENET-Serial x64 Support">
</feature>
<feature key="VISA_sysAPI.VSASYS" name="NI-VISA System API 18.5.0">
</feature>
<feature key="SysAPI_x64_support.VSASYS64" name="NI-VISA System API Support x64 18.5.0">
</feature>
<feature key="nierintf.NIERINTF" name="NI Error Reporting Interface 18.0">
</feature>
<feature key="nierintf64.NIERINTF64" name="NI Error Reporting Interface 18.0 for Windows (64-bit)">
</feature>
<feature key="NINetworkDiscovery.NETDSC" name="NI Network Discovery 18.1">
</feature>
<feature key="NINetworkDiscovery_W64.NETDSC64" name="NI Network Discovery 18.1 64-bit">
</feature>
<feature key="nisvcloc.LV.NISVCLOC" name="NI Service Locator 2018">
</feature>
<feature key="NISysAPI_Windows_x86.NISYSAPIX86" name="NI System API 18.5.0 for Windows 32-bit">
</feature>
<feature key="NISysAPI_Windows_x64.NISYSAPIX64" name="NI System API 18.5.0 for Windows 64-bit">
</feature>
<feature key="NISysCfg_Windows_x64.NISYSCFGX64" name="NI System Configuration 18.5.0 for Windows 64-bit">
</feature>
<feature key="NIAPXIPM.PXIAPM2" name="NI Atomic 2.0 PXIe Peripheral Module Driver">
</feature>
<feature key="niauth.NI.AUTH.2017" name="NI Authentication 2017">
</feature>
<feature key="niauth64.NI.AUTH64.2017" name="NI Authentication 2017 (64-bit)">
</feature>
<feature key="NI_Certificate_Main.SIGN01" name="NI Certificate CorePart">
</feature>
<feature key="niControllerDriver.CNTLDVR" name="NI Controller Driver 18.5">
</feature>
<feature key="niControllerDriver64.CNTLDRV64" name="NI Controller Driver 18.5 x64">
</feature>
<feature key="nicurl.NI.CURL.2018" name="NI Curl 2018">
</feature>
<feature key="nicurl64.NI.CURL64.2018" name="NI Curl 2018 (64-bit)">
</feature>
<feature key="NIIOTrace.IOT64" name="NI I/O Trace 64-bit Support">
</feature>
<feature key="logos.LV.LOGOS.1800" name="NI Logos 18.0">
</feature>
<feature key="LogosMSM.LV.LOGOS.1800" name="NI Logos MSM">
</feature>
<feature key="Logos64.LV.LOGOS64.1800" name="NI Logos 18.0 (64-bit)">
</feature>
<feature key="Logos64MSM.LV.LOGOS64.1800" name="Logos 64-bit">
</feature>
<feature key="LOGOS_XT.LOGOSXT.1800" name="NI Logos XT Support">
</feature>
<feature key="LogosXTMSM.LOGOSXT.1800" name="NI Logos XT MSM">
</feature>
<feature key="LOGOS64_XT.LOGOS64XT.1800" name="NI Logos64 XT Support">
</feature>
<feature key="NIMXIMAN.MXIMAN" name="NI MXI Manager 18.5">
</feature>
<feature key="NIMXIMAN64.MXIMAN64" name="NI MXI Manager 18.5 64-bit">
</feature>
<feature key="NIPXIRM.PXIPF32_1850" name="NI PXI Platform Framework 18.5.0">
</feature>
<feature key="NIPXIRM64.PXIPF64_1850" name="NI PXI Platform Framework 64-bit">
</feature>
<feature key="NIPXIPFERR.PXIPFERR32" name="NI-PXIPFERR">
</feature>
<feature key="NIPXIPFERR.PXIPFERR64" name="NI-PXIPFERR for 64-bit Windows">
</feature>
<feature key="NIPXIPS.PXIPS" name="NI PXI Platform Services 18.5">
</feature>
<feature key="NIPXIHW.PXIPS" name="Runtime Support">
</feature>
<feature key="PXI_Provider.PXIPRV" name="Configuration Support">
</feature>
<feature key="NIPXIHW64.PXIPS64" name="NI PXI Platform Services Runtime 18.5 64-bit">
</feature>
<feature key="niSysMon.PXISYSMON" name="NI System Monitor 18.5">
</feature>
<feature key="niSysMon64.PXISYSMON64" name="NI System Monitor 64-bit 18.5">
</feature>
<feature key="NIPXIExpert.PXIEX" name="NI PXI Platform Services MAX Expert">
</feature>
<feature key="pxiSwError32.PXISWERRORS32" name="NI PXI Platform Software Error Files 18.5">
</feature>
<feature key="pxiSwError64.PXISWERRORS64" name="NI PXI Platform Software Error Files 18.5 64-bit">
</feature>
<feature key="RegistrationWizard.REG103" name="NI Registration Wizard">
</feature>
<feature key="ssllvrte.LV.SSLRTE2017" name="NI SSL LabVIEW RTE 2017 Support">
</feature>
<feature key="ssl.SSL.2018" name="NI SSL Support">
</feature>
<feature key="ssl64.SSL64.2018" name="NI SSL Support (64-bit)">
</feature>
<feature key="NISysLogUtils.NI.SYSLOGUTILS" name="NI System Logging Utilities">
</feature>
<feature key="TraceEngine.LV.TRCENG.2018" name="NI Trace Engine">
</feature>
<feature key="TraceEngine64.LV.TRCENG64.2018" name="NI Trace Engine (64-bit)">
</feature>
<feature key="wsRepl.NI.wsRepl.2017" name="NI WS Repl Library 2017">
</feature>
<feature key="wsRepl64.NI.wsRepl64.2017" name="NI WS Repl Library 2017 (64-bit)">
</feature>
<feature key="Portable_Configuration.MAXPC" name="Portable_Configuration">
</feature>
<feature key="Portable_Configuration64.MAXPC64" name="NI Portable Configuration Support 64">
</feature>
<feature key="mxrmcfg.MXRMCFG" name="MAX RmCfg 18.0">
</feature>
<feature key="mxrmcfg64.MXRMCFG64" name="MAX RmCfg 64-bit 18.0">
</feature>
<feature key="ResetNIConfig_x86.RESETNICFG" name="Reset NI Configuration 18.0.0">
</feature>
<feature key="Kill_Bit_Patch.NI.KILLBIT.200" name="NI Security Update (KB 67L8LCQW)">
</feature>
<feature key="Kill_Bit_Patch_64.NI.KILLBIT_64.200" name="NI Security Update (KB 67L8LCQW) (64-bit)">
</feature>
<feature key="NI_MSSL_Core.MIFMSSL" name="Microsoft Silverlight 5.1">
</feature>
<feature key="NI_MSSL_Wrapper64.MIFMSSLW64" name="NI Silverlight 5.1 x64 Wrapper">
</feature>
<feature key="tdms.NI.TDMS" name="TDM Streaming">
</feature>
<feature key="TDMSmsm.NI.TDMS" name="TDMS Merge Module">
</feature>
<feature key="tdms64.NI.TDMS64" name="TDM Streaming">
</feature>
<feature key="targetwizard.TRGTWIZ" name="NI Remote System Discovery Troubleshooting Wizard 18.5">
</feature>
<feature key="UpdateServiceFeature.US.CORE" name="NI Update Service 17.0.1">
</feature>
<feature key="UpdateServiceFeature64.US.CORE64" name="NI Update Service 17.0.1 (64-bit)">
</feature>
<feature key="CoreInstall.VSADNSC581" name="VISA.NET Shared Components">
</feature>
<feature key="VisaNetSC64.VSADNS64581" name="VISA.NET Shared Components 64-Bit fake feature">
</feature>
<feature key="CoreInstall.VSASC" name="VISA Shared Components">
</feature>
<feature key="VisaSharedComponents64.VSAR03" name="VISA Shared Components 64-Bit fake feature">
</feature>
<feature key="XERCES_NI.XERCES.NI.001" name="NI Xerces Delay Load 2.7.9">
</feature>
<feature key="XERCES_NI_64.XERCES.NI.00164" name="NI Xerces Delay Load 2.7.9 64-bit">
</feature>
<feature key="mDNS_Responder.MDNS01" name="mDNS_Responder">
</feature>
<feature key="mDNSResponder_W64.MDNSW64" name="NI mDNSResponder 17.0 for Windows 64-bit">
</feature>
<feature key="NIVISA.VSARU" name="NI-VISA 18.5">
</feature>
<feature key="CoreInstall.VSAMETA" name="NI-VISA Meta Package">
</feature>
<feature key="visaic.VSAIC" name="NI-VISA Interactive Control">
</feature>
<feature key="VISA_Provider.VSAMP" name="VISA Provider for MAX">
</feature>
<feature key="VISA_Provider64.VSAMP64" name="VISA Provider x64 Support for MAX">
</feature>
<feature key="Run_Time_Support.VSARU" name="Runtime Support">
</feature>
<feature key="VISA_core.VSARU" name="VISA core">
</feature>
<feature key="GPIB.VSARU" name="GPIB">
</feature>
<feature key="PXI.VSARU" name="PXI">
</feature>
<feature key="Tulip.VSARU" name="TULIP">
</feature>
<feature key="VISA_support.VSARU" name="VISA support files">
</feature>
<feature key="API.VSARU" name="I/O Trace API">
</feature>
<feature key="Serial.VSARU" name="Serial">
</feature>
<feature key="Ethernet.VSARU" name="Ethernet">
</feature>
<feature key="Remote.VSARU" name="Remote">
</feature>
<feature key="Enet_Serial.VSARU" name="ENET-Serial">
</feature>
<feature key="USB.VSARU" name="USB">
</feature>
<feature key="COM_Support.VSARU" name="COM Support">
</feature>
<feature key="Development_Support.VSADS" name="Development Support">
</feature>
<feature key="Development_Common.VSADS" name="NI-VISA Development Common">
</feature>
<feature key="CoreInstall.VSADEVCOMPAT" name="NI-VISA Development Compatibility Package">
</feature>
<feature key="Examples.VSAXMPL" name="Examples">
</feature>
<feature key="Driver_Development.VSADDW" name="Driver Development">
</feature>
<feature key="VISADotNet32.VSDND1750" name=".NET 4.0 - 4.5.1 Development Support (IVI)">
</feature>
<feature key="VISADotNetExamples.VSDND1750" name="Examples">
</feature>
<feature key="Server.VSASV" name="Remote Server">
</feature>
<feature key="DotNetRuntime.VSADN1750" name=".NET 4.0 - 4.5.1 Runtime Support (IVI)">
</feature>
<feature key="NIIOTrace.IOT32" name="NI I/O Trace 18.5">
</feature>
<feature key="NISysCfg_Dummy.NISYSCFGX86" name="NI System Configuration 18.5.0">
</feature>
<feature key="NISysCfg_Windows_x86.NISYSCFGX86" name="NI System Configuration Runtime 18.5.0">
</feature>
<feature key="MAXROOT.MAX00" name="NI Measurement & Automation Explorer 18.5">
</feature>
<feature key="MAXMAX.MAX00" name="The MAX Files">
</feature>
<feature key="RemPXI_core.REMPX" name="RemPXI_core">
</feature>
<feature key="Remote_Provider.MAXRM" name="Remote Provider">
</feature>
<feature key="Software_Provider.MAXSW" name="Software Provider">
</feature>
<feature key="_NI_1588_2008_Network_Management" name="NI 1588-2008 Network Management 18.1.0">
</feature>
<feature key="ptp_sys_api_64.PTP.SYSAPI641810" name="NI 1588-2008 Network Management 18.1.0 (64-bit)">
</feature>
<feature key="ptp_sys_api.PTP.SYSAPI1810" name="NI 1588-2008 Network Management Runtime 18.1.0">
</feature>
</features>
<customExecute>
<customExecute name="National Instruments help uninstall from Visual Studio 2010">
<commandLine>"HelpLibManager.exe" /product VS /version 100 /locale en-us /silent /uninstall /vendor "National Instruments" /productName "NI Measurement Studio" /mediaBookList "Measurement Studio Base Help"</commandLine>
<returnCode>2</returnCode>
</customExecute>
<customExecute name="Uninstaller Update Utility">
<commandLine>"C:\Program Files (x86)\National Instruments\Shared\NIUninstaller\uninst.exe" /NIARP Show</commandLine>
</customExecute>
<customExecute name="Stop Web Server Service">
<commandLine>"C:\Program Files (x86)\National Instruments\Shared\nisvcloc\installer\unloadServiceHelper.exe" stop niSvcLoc</commandLine>
</customExecute>
</customExecute>
</installDetails>
Solved! Go to Solution.
02-21-2019 06:37 PM
Hey try these steps:
02-21-2019 06:44 PM
Many thanks. Later our IT solved the problem. Some of our security software keep blocking NI install. After they uninstall the security software (later installed them back), the installing goes well. Thanks again.
