Simple Serial.vi changing command string to string-type shared variable
I am trying to communicate with VISA Serial instruments and I did it with example - Simple Serial.vi. However, I would like to use network-published shared variable (string type) to send command to the instruments by replacing the string command (*IDN?\n) to the shared variable with same command loaded into the variable. Figure below shows the Simple Serial.vi added into a .lvproj file and a shared variable "READ" is preloaded with exactly same command.
May I know how to make it work as I am unable to communicate with the instrument once I changed the string command to shared variable?
Thank you.
Wing
(2,370 Views)
Attached with the zip file for the Simple Serial.lvproj
(2,342 Views)
First I will state that I advise against Network Published Shared Variables.  They are slow, unsecure (anybody on the network can update the value), and often have weird race conditions.  What what is it that you are actually trying to accomplish?  There are likely better ways.
On the serial side, we need to know the device and its command structure in order to help at all here.  Again, I advise against using the NI example.  You might want to have a look at this: VIWeek 2020/Proper way to communicate over serial
(2,332 Views)
Hi
(2,304 Views)
Accepted by wing98
Hi all,
I solved the NPSV problem by removing the termination characters in variables and adding Term Char manually to write into the machine and it works fine with my three different instruments.
Thank you all for your replies.
Wing
(2,276 Views)
