Siglent sdg1020
Hi.
I've been trying to use USB to control an Siglent SDG1020 function generator but haven't been able to see the instrument neither in NI MAX nor in LabVIEW.
I checked the drivers in device manager and it is not the NI driver (brus.sys). When installing the device driver system finds the manufacturer .inf –file and then asks for the appropriate .sys – file and the only accepted .sys file in that case is a manufacturer driver brus.sys (I also tried to change the device driver to ausbtmc.sys but with no success (windows refused with the message “No device specific information found”)). After the driver installation the device shows up in the device manager tree under the branch “USB Device Controllers” as a “USB Test and Measurement Device Controller”.
I also tried to do the same with the Rigol oscilloscope. With no success. The only difference was the driver system installed by itself (ausbtmc.sys located in windows/susten32/drivers) and the device shows up in the device manager as USB Test and Measurement Device (IVI). NI MAX and NI LabView was not able to recognize the device. (I use NI LabView 2015 and NI VISA 14.0.1)
Everything went well (literally as it is shown in this video: http://www.ni.com/webcast/1434/en/) only with the Tektronics oscilloscope.
As an operating system I’m using Windows XP Home Edition SP3 x86.
I will be gratefull for any replay.
(5,375 Views)
Hi Luk_Gluk,
Is this the Siglent Driver you downloaded? http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=24731
With the driver linked above, the zip file comes with LabVIEW examples that should work with your device. Give that a try and see if it works.
Regarding the Rigol Oscillioscope, it seems like this driver isn't supported or maintained by National Instruments: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=A7F379F7B32474CBE0440021287E6A...
Shalini M.
Partner Development Engineer
Alliance Partner Network
(5,347 Views)
Hi, Shalumdawg.
Thank you for your reply. Yes, I used the same driver you mentionned and it works as it should now. My problem was that I didn't know that the USB Interface of the Siglent generator is set to USB::RAW by default. So I changed it to USB::TMC (may be it will be usefull for somebody: press the button Utility (on the front pannel of the Generator) then go Interface -> USB Setup -> USB TMC - > Done. That done you will see your device in the device manager under the USB Test and Measurement Devices -> USB Test and Measurement Device (IVI). If NI VISA is installed properly, system assigns ausbtmc.sys driver to your device automatically. Now you can see your device in NI MAX and assign it a new name.)
Best regards, Lyubomyr
(5,337 Views)
That's really works. Thank you Lyubomyr!
(767 Views)
