취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
Shiftout with 32 bits long -ADF4351 registers
해결 완료!
솔루션으로 이동
    1. hello,
      I need to send 32 bits (5 times) to a PLL circuit (ADF4351)
      using PBP V2.x and a small PIC (lets say 12F675)
      As far as I understand Shitout command can deal with WORD not double word ..
      If I send first the first word using Shiftout and immediatly send the second word
      usin a shiftout command, do you think that it will be OK ?
      or may be , you have a better solution ...
      thanks
    I will be much appreciated if you could provide me some help.
0 포인트
1/3 메시지
3,955 조회수
솔루션
주제 작성자 Adgfsdg이(가) 승인함
guessing that you use the pic to accept the data it is all up to you.
the pic can buffer the word and send the 16 bit as one block.
0 포인트
2/3 메시지
3,939 조회수
Thanks!
0 포인트
3/3 메시지
3,558 조회수
