Set to Remote State
I have a application that control a California Instruments power source. On any command I send to the ps, it displays a error that I must turn it in remote state. But I can't find a scpi oder gpib command that I can use for it (with "system:remote" the error appears too). Has anybody a solution?
Sorry for my bad english
Greets André
(3,276 Views)
You have to assert the REN line and address the device to listen. If you are using NI-488.2, this should be done automatically by the driver if you are using device-level calls. If you are using board-level commands (or IEEE 488.2-style commands), you would use either ibsre (or EnableRemote). The addressing of the device to listen will happen automatically when you send the first string to the device.
Good luck.
(3,265 Views)
