Fatal Internal Error being generated on runtime
While making an application which controls instruments over GPIB and uses Excel for generating report , the following error occured
INSANE OBJECT "dataspace typemap" in cal2-test.vi:{sub} (0x10)
Fatal Internal error : "fpsane.spp" ,line 203
any solution for the above problem. The program was working OK till sometime ago. Now I can't even edit the block diagram
Message 1 of 1
(3,344 Views)
