Hello Petri,
The instrument you are using obviously does not support the LAN instrument protocol and therefore you use the platform independent socket API VISA provides.
I believe you have read the VISA manual where it says that by default, only the read and write operations are valid. If the device recognizes 488.2 commands such as "*TRG\n" and "*STB?\n", you can set the attribute VI_ATTR_IO_PROT to VI_PROT_4882_STRS (4) and then use the operations such as viAssertTrigger() and viReadSTB(). However, unlike LAN instruments, there is no way to support the service request event with the SOCKET resource class.
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
