If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
04-11-2012 01:36 PM
Hi Eric,
Maybe you can try to read an address and see what your slave returns.
The CRC calculation method is always the same.
Kees
04-13-2012 03:00 PM
Hi Kees,
I decided to try with the MODBUS library from labview because i was becoming crazy trying to write my own cmd...
Good news... I can read and write SOME registers...
I don't understant why, if you look at the register table i sent to you recently, I can do what ever I want from the list from page 72 to 85 (what they seem to call legacy parameters table).
But whenever I try to do read/write another address higher then 760 (40761), i have an illegal address error code. Any idea why?
Example: If I try to read the address 44804 (4803 from labview) I got the error.
Slowly... getting through it...
Eric
04-17-2012 05:40 AM
Hi Eric,
Had a long weekend. No computer no forums ... no NI
Now it is getting device specific. I see no reason why you cannot communicate with the mentioned addresses.
Kees
04-17-2012 07:00 AM
Hi Kees,
Yes, long and hot weekend (here in Canada). Warn weather is finally coming up.
Ok well thx a lot for your help, it helped me a lot.
You are good 😉
Bye,
Eric
04-30-2012 06:25 AM
Could you please convert it to 2009SP1. I can't open 2011.
05-01-2012 09:59 AM
Hi Yasemin,
Which file do you need converted?
Best,
05-01-2012 10:01 AM
Hi
This one? Let me know if it works.
Eric
05-02-2012 10:58 AM
Hello Courtney,
05-03-2012 04:24 PM
Hey Yasemin,
These should do the trick.
Best,
05-03-2012 04:27 PM
Thank you very much, they worked.
