Serial Communication with Watson-Marlow pump 505Di
I was trying to get the pump programm form Watson Marlow but the support wasnot very helpfull.
Could you send me the programm if i give you my mail adress??
Best regards, Stefan
Message 11 of 15
(1,237 Views)
I would use a program called RealTerm to try to communicate with the pump manually over RS232 first.
I think the issue I was having was not putting a carriage return after my commands.
Message 12 of 15
(1,235 Views)
Hi
I did the same, they ask me to buy the replacement pump, but the old one is working, i just want to get the support to connect it to the PC. have you got the supporting software? it is possible for me to have the software if i tell you my email?
Message 13 of 15
(908 Views)
You can download RealTerm here:
https://realterm.sourceforge.io/
Follow the directions in the manual for the pump, but add a carriage return character after each line for the commands you send to the pump.
Message 14 of 15
(905 Views)
Thanks for your help, i have made the pump working. i was not using the right cable before.
Message 15 of 15
(865 Views)
