Serial Communication by VISA: what' s wrong ?
Post the log in a readable format - i.e. as plain text and attach the manual for the instrument. You do have a copy of the manual don't you? There is not much sense in trying to communicate if you don't have the manual.
Read length is 0 because there is nothing to read and there is nothing to read because probably you are sending an incorrect command or the command is not formatted correctly.
I will also repeat my suggestion to try hyperterminal first.
Message 31 of 34
(1,311 Views)
Hi
this is the log in .doc
Message 32 of 34
(1,293 Views)
How we can see in the original logs there is a different string line
0             0.00036206         Col60.exe             IRP_MJ_CREATE   Serial0   SUCCESS                Options: Open
that  there isn't in logs by labVIEW; maybe this is the problem?? i'm explaining better: with LV there isn't that string line and i guess that comunication is not already to start!!!!
Another question: the signal  that  we can see in LV logs
5             0.00000475         LabVIEW.exe        IOCTL_SERIAL_SET_RTS     Serial0   SUCCESS
6             0.00000475         LabVIEW.exe        IOCTL_SERIAL_SET_DTR     Serial0   SUCCESS
there aren't in original logs...this is important or not?
Message 33 of 34
(1,292 Views)
I don't think the first line is important at all.
The handshaking is very important and if you don't have that correct, you will not communicate. I don't have portmon installed right now so I can't experiment. What exactly do you have flow control set to when you run the VI? You know the baud rate/parity/data bits/stop bits so you can try different flow settings.
Your lack of mention of a progamming manual after repeated requests is disturbing. Have you even tried contacting the vendor?
Message 34 of 34
(1,280 Views)
