maximum speed using GPIB only and E3643A
Hi
I am using Labview 8 to control an E3643A power supply. The link is
via GPIB using the NI USB-GPIB converter. I have written a simple
application which is an infinite loop that swtiches the supply between
0V and 10V. My objective was to see how fast the system would run.
When I look at the power supply output on a scope I see that the
voltage changes every 50msec. The PC is not doing anything else.
I use VISA for the comms. Does this seem reasonable? Should I see
the voltage switching faster? I tried changing different things : for
loop , while loop , GPIB write , etc but nothing changed the basic
switching time of 50msec.
Thanks.
Paddy.
(3,708 Views)
That's well under the maximum settling time that is in the specs. Were you expecting something else?
(3,701 Views)
As Dennis said. this is expected. 50ms is fast for a powersupply via gpib. Gpib is faster, most instruments communicate in the 10ms range.
And windows is adding jitter to that. I you need fast IO I would use a multifunction IOcard for IO.
1 us is then easily achieved.
greetings from the Netherlands
(3,698 Views)
Thanks for the replies. There is no nothing so
easy to miss as the glaringly obvious.
(3,671 Views)
