Sending differentes instructions via RS232
Firstable sorry for my English, and thank you to google translate
I try to communicate with a receiver via the RS232 port.
Instructions to be sent are like that:
RF8507000
MD2
AT1
BW1
My concern is in sending the data in the "visa write".
In fact, I found a solution with the use of an "End of Line Constant" at the end of each command,
but this slowed sending information.
When I send a single frame, the transfer is made immediately, but this approach does not satisfy me, because I want to send several different information.
I thought only send frames that change in the buffer, but I do not see how.
Do you think that my track is good? Or do you have another solution?
Message 1 of 11
(5,393 Views)
Message 2 of 11
(5,388 Views)
Your approach is not at all correct. You do not want to be constant transmitting. I would suggest you look at the event structure so a command is sent only when a control value changes.
LabVIEW 101
Message 3 of 11
(5,384 Views)
Thank you for you answers.
Unfortunately, I have the base development System. (LV 2011 SP1)
The "Event Structure" and "value change event" are with the Full version. Do you think I can do something with another VI ?
Thank you
Message 4 of 11
(5,364 Views)
Thank you
Huh????
Event Structure is most definitely in the Full version.
Message 5 of 11
(5,353 Views)
nyc a écrit :
Huh????
Yes it is in the Full version, but I have the Base version
Message 6 of 11
(5,350 Views)
I haven't worked with base development System but I'll be surprised if they're not included.
Message 7 of 11
(5,323 Views)
Accepted by scab1984
Just in case however, attached is a variation of your code. While what I've provided might be of some use to you, this really is a crude way of doing things. But I hope you can see the various methods that you could employ in order to do what you want.
Message 8 of 11
(5,322 Views)
The event structure has not been in the base version.  That changed with LV2012.
Message 9 of 11
(5,308 Views)
Ok, thank you, I'll check this Vi tomorow.
Message 10 of 11
(5,300 Views)
