Screen Capture of MSO4104 using Labview
Hi All,
 I am trying to acquire a screen capture from a Tektronix MSO4104 oscilloscope using LabVIEW. I currently am able to collect data from the device, and have a waveform displayed on my VI front panel. However for various reasons, our preference is to capture the actual screen shot from the scope. I have tried ryan gs method, but for some reason i cant get it to work on the MSO4104. If anyone can share the solution for the MSO4104 that would be great. Thanks
(1,832 Views)
1. I recommend using a png format.  It is A LOT smaller than a bitmap and is a lossless compression.  PNGs work amazingly well for scope plots.
2. You will want to turn off the termination character when doing the hardcopy because a byte that just happens to be the termination character will stop to VISA Read.
3. Unfortunately, the transfer protocol does not have a file length in it.  So what I did was use a short timeout (something like 500ms) and read the data in chunks.  If I got a timeout, it is fairly safe to assume I got the whole file.  You will want a delay after the VISA Write to make sure you don't get a timeout before any data comes through (I think I used 100ms).
4. You will want to use the Open/Create/Replace File to actually create or replace the file before you start writing to it.  Be sure to close it when you are done writing.
You can see what I did for a TDS3000 scope (which, as far as I can tell, works the same) here: https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Screen-capture-of-Tektronix-MSO4104B-using-L....  It is dated (not including the timeout updates or turning off the termination character), but you can get some ideas.
GCentral
(1,808 Views)
Hi Knight,
I am little confused as to what i need to change. I have attached the VI, would you be able to annotate the changes?
(1,796 Views)
Here is a quick clean up of your code that I put together.  I think I incorporated everything.
GCentral
(1,785 Views)
Thanks so much. I am not in the lab just now to test, but i will most certainly let know how i get on.
Thanks again.
(1,777 Views)
