Orion Star pH Meter Serial Communication
I have a ThermoScientific Orion Star A211 pH meter which I am trying to communicate with using LabVIEW and the simple serial example VI. The manual says the command to send is GETMEAS. When I use Hyperterminal I have no problems sending the command and receiving the response. However in LabVIEW I only get an echo of the command and not the response string. Any ideas?
I did see this thread which seems to be exactly my problem but when I put in GETMEAS\r\n I still don't get any response. I am using LV2016.
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Orion-5-Star-pH-Cond-meter-double-string/m-p...
(5,301 Views)
Are you able to send any other commands or is it just this one? Have you sent a *IDN? command? Do you have NI-VISA installed and if so which version? Could you also link the manual if you found it online? I can't seem to find it.
(5,218 Views)
I actually just figured this out late yesterday after digging around some more. The issue was the response from the instrument was multiple lines and I needed to disable the termination character when configuring the serial port. I could see that the bytes at port was 119 but I was only getting back around 30 which was just the echo before the actual data.
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Serial-read-from-pH-meter-giving-me-varied-ou...
(5,213 Views)
I have the same problem with this model of pH meter, Would you please tell me how did you solve this issue?
Thank you
(3,382 Views)
Make sure enable termination character is F on initialization and wait about 1500 ms from a write command before reading back the data:
(3,366 Views)
Hello Nasu,
thank you so much for you help, could you please upload the Visa file, then I can work on that. I am stuck on this and my project has stopped just because of that. I appreciate your help.
(3,356 Views)
