 JB
			JB
			11-05-2015 08:31 AM
Has anyone already used a Schleich MTC2 surgetester ?
I'm looking for existing solutions to read the test results of the MTC2 with a LV application in order to store them in a file with a proprietary format.
At this point, no alternative is excluded.
Many thanks in advance for any advice.
11-06-2015 04:22 AM
Hi JB,
as the Interface page of the Schleich device shows:
The tester has several interfaces to communicate with the outside electric world. USB to save a test on a flash-drive RS232 to communicate and remote control a GLP1-e high-voltage tester VGA to connect a large external screen
The USB Port of the MTC2 seems to be a Master, so you will not be able to handle it as a slave to request data from the MTC2.
The RS232 seems only support a connection to their other devices like the GLP1-e.
So have you tried to get in contact with Schleich directly?
They should be the best to get information about what is possible through the busses the device supports.
As far as I could see in the documentation it is a very closed system.
11-06-2015 06:43 AM - edited 11-06-2015 06:44 AM
Yes I called the vendor yesterday and I am now waiting for its response. I am still very interested in the experience of other users.
Thank you for your time.
