SSI encoder simulation
I have to simulate an encoder with SSI interface, Please let me know a suitable hardware from NI.
The application is simple, my controller will clock the pulses, and my simulator should respond with simulated data that I will be sending through LabVIEW.
( I was thinking of using NI USB-485 - But I'm not sure if it will work)
Naveen
(2,070 Views)
Accepted by nforce_212
Unfortunately, there is no SSI compatible HW from NI. If you have NI FPGA cards, you can use SSI IP to implement on FPGA.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIBYSA2&l=en-US
Santhosh
Soliton Technologies
(2,033 Views)
