 annica
			annica
			05-12-2015 03:05 PM
I am currently trying to connect a SR830 Lock-In Amplifier to my computer with the help of a GPIB. I installed all drivers but it does not show up on either NI MAX or LabVIEW. I am wondering if I need to tell the Lock-In that it is controlled through the GPIB (I had to do something similar to a function generator). I know that the GPIB driver is installed correctly because I can connect other instruments and run them in LAbVIEW, just not the SR830 Lock-In.
I am using a GPIB-USB-HS (driver 14.0.0.49152), LabVIEW 2014, Windows 7 Enterprise. I am relatively new to this whole thign, so I appreciate an easy-to-understand answer, please.
I attached a screenshot of the NI MAX, I am seeing at the moment.
Thanks!
 nyc_(is_out_of_
			nyc_(is_out_of_05-12-2015 09:31 PM
Look in the manual.
05-12-2015 09:49 PM
 Dennis_Knutson
			Dennis_Knutson
			05-12-2015 10:52 PM
05-13-2015 08:48 AM
Thanks for your help! I did that a few times already but it never showed up on the NI MAX. I thought there might be something more complicated as a setup procedure. Is there anything else that could be the problem?
 Dennis_Knutson
			Dennis_Knutson
			05-13-2015 08:51 AM
05-13-2015 08:54 AM
It shows the above screenshot (sent it in my inital question). The cable works well with other instruments, so I guess it could be the lock-in itself?
 Dennis_Knutson
			Dennis_Knutson
			05-13-2015 08:57 AM
05-13-2015 09:06 AM
The instrument works fine! I don't know how old it is. It has been controlled with a DAQ before, so I guess you are able to connect it to the computer?
I don't know much about this kind of stuff, so I wouldn't know how to communicate through the serial port. How does that work?
 Dennis_Knutson
			Dennis_Knutson
			05-13-2015 09:26 AM
