SOS
Your caps lock key seems to be stuck on.
There are numerous examples at http://www.ni.com/devzone/idnet/ for DMMs. There is even a shipping example for the Agilent 34401 and this is on the Instrument I/O>Instrument Drivers palette. It is a GPIB or RS-232 instrument so you can look at how the serial is configured. There is also a lot of other resources at the above link. How and what a driver is, how to write one, etc. With LabVIEW 8.x, you also have a wizard for creating a driver at Tools>Instrumentation>Create Instrument Driver Project. You also have the Instrument I/O Assistant on the Instrument I/O palette. This is helpful if you don't want a full driver. In any case, I would recomend you get familiar with the remote control functions in a program such as hyperterminal before you start writing any code. When you've done that, you can test some of the functions with the shipping examples for serial communication.
Message 11 of 16
(1,633 Views)
Hi sir..why i am not being able to communicate with my device?while opening "visa test panel",it is unable to open it..the source is valid,but it cannot open visa..
Message 12 of 16
(1,631 Views)
Make sure you don't have any other communications programs running at the same time. Windows will not permit, for example, Hyperterminal and VISA simultaneous access to a com port.
Message 13 of 16
(1,624 Views)
Hi sir..can you tell me plz if i can find the Intrument I/O Assistant in LABVIEW 6?
Message 14 of 16
(1,607 Views)
If not,then,is there any alternative?
Message 15 of 16
(1,603 Views)
Sorry, the Instrument I/O Assistant was not introduced until LabVIEW 7.0. Short of upgrading, about your only alternative is to look at the shipping examples I mentioned and try to write your own driver.
Message 16 of 16
(1,598 Views)
