在 02-15-2012 01:42 AM
I am trying to install the SMC100 device drivers
The SMC100 controller drivers has been developed under LABVIEW 6.1.
So i installed also LABVIEW 6.1. run time engine.
I installed the drivers(in the link below) to the "instr.lib" file as required.
ftp://download.newport.com/MotionControl/Current/MotionControllers/SMC100/Software/
When i open the block diagram(functions pallette), the SMC100 drivers are seen as question mark like in the attached picture.
I am using Win7 32 BIT, LabVIEW 2009, and also
*My device still on the way from USA to Turkey, so i did not connect the SMC100 device to my PC yet. Is it smthg to do with this? Should i connect the device to install the drivers?
在 02-15-2012 10:08 AM
