SHC68-68-EPM SHIELDED CABLE- USB converter
Hi.
We have both the 782606-01 and 192061-02
But it’s seeming that the cabling connection between USB-6002 (782606-01) and 192061-02 is not matching each other.
Can you advise if there is any adapter/ converter that we can use to connect?
Or any other alternative that you can suggest? Thanks.
(1,338 Views)
As you can see from the USB-6002, the device comes with screw terminals and expect you to screw in the wires into those screw terminal block.
SHC68-68-EPM is NOT SUPPORTED for USB-6002, if you would like, you can create your own cable.
Learn more about compatible devices and cables here - https://www.ni.com/en-us/support/documentation/supplemental/17/68-pin-scsi-cables---daq-multifunctio...
Santhosh
Soliton Technologies
(1,336 Views)
