08-19-2008 02:11 PM
I have a SCXI-1001 Chassis connected to a computer through SCXI-1349 and it is working fine but I want to able to use it (read and write) from another computer through existing LAN. Is it possible ? What should I do and what do I need ? I have NIDAQmx 8.6 installed.
Thank you. |
08-19-2008 02:16 PM
08-19-2008 03:39 PM
I don't wish to control an application, but i wish to have access to max configuration. In other words, I want to share my SCXI-1001 between 2 computers and 2 independent applications. For exemple, an application is running on computer #1 and reading/acquire data from the chassis at the same time computer #2 is reading data from the same chassis. Is it possible to share a chassis and its configuration over local network ? Is it possible to control the chassis over local network ?
Greetings from Canada 🙂
The schematic of the system I want to create in attachement.
08-19-2008 04:05 PM
