Remote PXI controller instsrument control
Can you suggest the best method for controlling PXI instruments with an external controller?  I have two machines.  One standard desktop system and one PXI chassis with controller and instruments installed.  I can remote desktop to the PXI chassis.  I was hoping for MAX to recognise instruments in the PXI chassis from my desktop machine and use the VISA address as if it was local.  If possible pleas provide examples for a starting point.
Thanks!
Message 1 of 9
(6,935 Views)
Thanks!
I am not sure I understand what you are asking.
Your choices are outlined here  http://www.ni.com/pxi/whatis/#tab2
Message 2 of 9
(6,928 Views)
Two controllers... one in PXI chassis with instruments. The other desktop machine connected via ethernet. I want to control the instruments in the PXI chassis with the desktop controller via ethernet.
Message 3 of 9
(6,925 Views)
It doesn't matter what you want. It matters what NI tells you is available.
You still haven't said which type of controller you have.
Message 4 of 9
(6,915 Views)
Ok. Keysight controller M9037A and a HP Z440.
Message 5 of 9
(6,908 Views)
It looks like you have all Keysight/Agilent equipment so I am not sure why you are here on the NI forums.
Message 6 of 9
(6,900 Views)
LOL.... you are right. Did I mention that I'm using labview?
Message 7 of 9
(6,894 Views)
That doesn't change anything.
You should stop wasting your time here and actually talk to someone at Keysight.
Oh, and your only options are still the same as the ones outlined in the link I gave you above.
If you fail to understand that link, I suggest you actually talk to someone at Keysight.
Message 8 of 9
(6,889 Views)
Accepted by topic author JG-MACK
The kind support team at Keysight helped me fix this problem.  They pointed me to MAX remote system control and walked me through the setup.  The link they sent me was from the following site NI website.
http://digital.ni.com/public.nsf/allkb/F3AB0B5D7DBA367C86257982005BBF2C
Thanks Keysight!
Message 9 of 9
(6,862 Views)
