Read GPS Time, Position, Velocity.vi - Error -1073807360 occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi
We are trying to receive information such as Latitude and Longitude from a Garmin GPS18xLVC receiver via a serial port on our PC using LabView 7.1.  I have successfully connected the GPS unit to the serial port and tested it with HyperTerminal.  I have tried the Read GPS Time, Position, Velocity.vi multiple times and continue to receive the following error: Error -1073807360 occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi.  I think that it has something to do with the configuration of the VISA Serial sub vi.  Any suggestions would be greatly appreciated.
Message 1 of 13
(6,228 Views)
Accepted by GrantD
I have figured out the issue I had with the Read GPS Time, Position, Velocity.vi.  The vi. does not "open" the com port automatically and therefore I had to modify the Read NMEA GPS SubVI to first open the port (VISA Open command) and then continue with the other operations.  Once I done that it started working fine.  I don't understand why that function was left out as it won't work without it.  I have tested the code with a Garmin 18xlvc reciever and it seems to work fine.
Message 2 of 13
(6,210 Views)
What version of NI-VISA are you using? For quite a few years, the VISA Open has been optional since the resource is automatically opened.
Message 3 of 13
(6,202 Views)
Dennis,
I believe that it is NI-VISA 3.1, according to my install CD's.  I am using LabView 7.1.
Grant
Message 4 of 13
(6,199 Views)
That's old and you could upgrade but I used that version for years with 7.1 and never had to use the VISA Open, at least with a normal serial port. I don't understand why it would start to work by adding a VISA Open.
Message 5 of 13
(6,196 Views)
This is my first project with LabView and it has been somewhat of a steep learning curve.  My background is in industrial SCADA software such as Wonderware and WinCC.  I am starting to get the hang of it now and am impressed with the functionality.  I don't know what to tell you about the VISA Open function.  I do know that it will not work with out it.  I have been fighting it for a couple of days now.  I knew it had to be something "simple".
Message 6 of 13
(6,192 Views)
i'm using LabVIEW 7.1. can any one tell me where i do find Read GPS Time, Position, Velocity.vi
Message 7 of 13
(5,152 Views)
This thread is over 3 years old, and OP hasn't visited since then.
If you're reading NMEA strings from a GPS receiver, use VISA to read the sentences from the receiver, find the word in the sentence and parse the value(s) to the appropriate format.
Message 8 of 13
(5,148 Views)
Thanks for replying.... actually i want to calculate longitude & latitude using GPS... this GPS system will be situated on a road roller. Can u plz tell me how to do it...?
Message 9 of 13
(5,144 Views)
What GPS receiver are you working with? Please elaborate on what you are trying to do and where you are having trouble.
Rohama K.
Message 10 of 13
(5,119 Views)
