RS232 - Issues
Hello
I am using the serial Visa functions to communicate with an external device.
The programme works fine (all sent commands are properly echoed) and I do receive the data properly (the device conditions and records data from a load sensor).
However, the soft does work fine on a desktop but if I move it on a labtop (with a RS232 connection, I tried on 2 computers), I got erratic errors in the data (some of the data, not all, are erroneous). I download the data from the daq by blocks.
Do you have any explanation for this?
Thanks for your help
Regards
Thomas
(3,266 Views)
Hi Thomas,
Do you use any handshake and/or protocol with your device ?
(3,260 Views)
Check also the power (voltages) on the serial line.
Officially they should be + and - 12 Volt but a lot of laptops cheat.
greetings from the Netherlands
(3,252 Views)
