RIGOL DS2072 - USB NI-VISA Initialization Error
Great! Thanks for your proactive help, Sunshine.
- Charles
Message 11 of 18
(3,527 Views)
Hello All,
I have RIGOL's scopes DS2202, DS4034, DS6104.
OS Windows 7 64-bit.
Certified LabVIEW Plug and Play (project-style) Instrument Driver for these models is named:
RIGOL DS2000 DS4000 DS6000 Series  Oscilloscope.
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=CEDF09A2AA8F261BE0440021287E65...
It mentioned:
Models Tested:
DS4054, DS6104, DS2202
Only DS6104 passes without error "the viClear function in the Initialize.vi".
it means models DS2XXX and DS4XXX were not tested.
Charles.Tac proposed a reasonable workaround, but every new installation will owerride it.
Sergiy
Message 12 of 18
(3,421 Views)
Hi sergiy,
I don't have one of the instruments to actually test with, but I have reviewed the code. Are you attempting to use the initialize vi directly? If so, can you get a response from the ID request? Also, does it crash with reset set as true, false, or both ways? Also, does this work properly with MAX test panels?
Message 13 of 18
(3,402 Views)
Hi Christopher,
1. DS2, DS4, DS6 work properly with MAX test panels. MAX just sends "IDN?".
2.
Original Reset.vi
My Reset.vi
3. Charles.Tac described workaround for Initialize.vi.
DS6 works.
DS2, DS4 work if you delete or disable "the viClear function in the Initialize.vi".
Message 14 of 18
(3,389 Views)
What is your question?
Message 15 of 18
(3,384 Views)
I was hoping you'd answer Dennis' question, as I am also having trouble determining exactly what your question is. I can offer some input though.
I am not directly familiar with the instruments in question, but as you have discovered in your reset function, sending multiple commands without any delay in between can sometimes cause issues depending upon your instrument and the settings of your interface device.
Is it possible that you are attempting to use HS GPIB, as outlined in this white-paper?
http://www.ni.com/white-paper/4552/en/
If so, and I'll admit this is somewhat of a guess, you're T1 delay may be too short. I am not familiar with, and don't readily have access to, the IEEE standards document mentioned so I can't say this definitively.
If you need a particular aspect of this research further, let me know and we'll see if we can't narrow down the scope of the inquiry a bit.
Message 16 of 18
(3,361 Views)
Hi Christopher,
Sorry, it was not clear for me whom does Dennis ask.
We can close this post.
Sergiy
Message 17 of 18
(3,356 Views)
I dont know if it will solve your problem but I found this tutorial how to setup Visa connection with Rigol DS1074Z oscilloscope. Maybe it is also applicable for Rigol DS2072
http://linkbone.com/rigol-oscilloscope-remote-control-visa-scpi/
Message 18 of 18
(3,284 Views)
