cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
RECALL SETUP
Hello!! How can i racall a setup that is stored in my scope tds 3052;; i ve downloaded the driver needed but i cannot find an appropriate vi..thanks..
Mensagem 1 de 4
3.802Exibições
Did you first search the manual to see if there is an appropriate command? If there is, you ca simply use it with a VISA Write.
Mensagem 2 de 4
3.789Exibições
Good Morning!
I had a couple of questions for so I can try and clarify what exactly you are trying to do. What do you mean by recalling a setup that is stored in your device? Also have you downloaded this driver:
(http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=014E9F890ACE6DA0E0440003BA7CCD...)
 and seen if there is anything in it that does the function that you want.
Best Regards,
Adam
Applications Engineer
Mensagem 3 de 4
3.753Exibições
Hello Dead Poet,
       I highly recommend that you explicitly configure all of your important instrument settings in your application.  This is generally preferrable to relying on the previous (or stored) instrument settings.  Explicitly configuring all of the settings is a more robust and portable approach.
Cheers,
NathanT
Mensagem 4 de 4
3.731Exibições
