‎08-04-2006 01:45 AM
‎08-04-2006 01:47 AM
‎08-04-2006 02:34 AM
Hi Jacky
This is an old list explaning the 25 to 9 pole change
pin 9 pole subD (male) 25 pole direction
1 DCD Data Carrier Detect 8 to pc
2 RXD Receive Data 3 to pc
3 TXD Transmit Data 2 from pc
4 DTR Data Terminal Ready 20 from pc
5 SG Signal Ground 7 both sides
6 DSR Data Set Ready 6 to pc
7 RTS Request to Send 4 from pc
8 CTS Clear to Send 5 to pc
9 RI Ring Indicator 22 to pc
(be careful the 25 pole and 9 pole connector have changed 2 and 3)
What you seem to miss is the direction of the signal.
RTS comes from the pc to signal that it is ready to receive
CTS comes from the device to stop sending by the pc
So CTS is controlled by the instrument and the library reacts on that by kleeping its mouth shut
‎08-04-2006 03:22 AM
‎08-04-2006 09:05 AM
