Python pyvisa NI-9251
Is there any guidance and interfacing NI-9251 to Python.  I've used pyvisa in the past but cannot find any info on interfacing to the NI-9251.  I want to understand NI-9251 interfacing prior to purchase.
(3,368 Views)
Accepted by dhaas
It is quite understandable that you find no information on using pyvisa to talk to that DAQmx device.  VISA does note support DAXmx Devices NI-DAQmx is the driver.
You may want to start here  and Here for a start at using the c-types module to call into the DAQmx C API
"Should be" isn't "Is" -Jay
(3,344 Views)
