Prologix GPIB LabVIEW error 1073676294
I am getting an error code 1073676294 on one of my GPIB read steps. It is a Prologix GPIB. The LabVIEW program is supposed to plot Lock-in voltage in one graph and o-scope voltage in another graph. The setup is for taking piezoelectric measurements using a homodyne laser set up. I have attached the vi in hopes that it may useful to anyone who can help me.
(3,783 Views)
Accepted by AM33
Hi AM33,
I looked into the code you received and found some documentation that might be helpful for you. It talks about how the code you are seeing is simply a status code, and not an error. If you wish to not see this code when you run your application in the future, consider following the steps in this document
Hopefully this helps.
Best Regards,
Thomas B.
Applications Engineer
(3,771 Views)
