Problems with the communitcation between PC an ag33120 over serial connection
Hello altogether
in the moment I try to estalbish a conncection with the ag33120a with the PC.
I use the VI's from the NI-Site for LabView 7.1. But when I start the ag33xxx - Initialize.vi
I get an write timeout error after the first VISA write.
Find attached the Initial Vi I use.
Have anybody an idea to solve the problem?
Message Edited by DoZi on 12-06-2007 03:46 AM
(3,434 Views)
Here are some suggestions:
- Verify that you have NI-VISA installed
- Verify that you are using the correct VISA resource name - check in MAX
- Verify that the serial settings on the instrument exactly match the serial settings in the driver
(3,415 Views)
Did you configure your instrument through MAX before running Initialize?
The settings in MAX and the instrument need to be the same.
(3,411 Views)
And be sure to have the correct serial cable
at least two versions exist. straight and crossed !
greetings from the Netherlands
(3,395 Views)
