Problems with communicating Delta Power Supply
Hello all,
I'm trying to establish a connection with a Delta Power Supply (SM 6000 series)
However, I'm having troubles reading/writing from it.
The device is connected through a Ethernet cable.
Windows recognizes 'a' device, but while running an example program, I get an error (10093)
I've allready tried using MAX to configure the device, but while setting up the connection using the IP-adress, it says that there is no device connected.
I've changed the IP-adress of the device multiple times, but there's still nothing happening.
Does anyone have any experience with Delta machines?
Thx in advantage!
(3,369 Views)
Accepted by topic author WickedWalker
Nvm I fixed the problem!
After trying different variations of IP-adresses and subnet IPs, I just released all IPs.
After the PC restarted, it worked correctly 🙂 I just had to reinitialize my internet!
I hope this helps people with the same problem in the future!
(3,347 Views)
