Problem with USB test and measurement device in Visa 5.1.2. While before it work
I have a problem with my Chroma 63600 DC-electronic load. When I use Visa 5.1.2 and connect the load then it is not installing the Test and measurement device driver correctly. My computer even hangs. With version of Visa 4.1 it works without any problem.
I am using Windows 7 and Bits
(8,146 Views)
To make sure the OS is Windows 7 and 64bits
(8,138 Views)
Thanks for your posting in this forum.
If you can see in the link below the maximum NI-VISA version of Chroma products is 4.2. That means you can use the older version for that.
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E909D659CE034080020E748...
Hope you can be able to use the version 4.2 of the NI-VISA.
If you have any other question don't hesitate to ask.
Hossein
(8,106 Views)
Accepted by topic author Martie
Problem solved: After  install the VISA Shared Components version 1.4 first uninstalleing then installing everything works properly. Refer to:
http://www.ivifoundation.org/shared_components/
(8,091 Views)
Did not work.
Researching for various fixes to get the device working.   Even tried a newly reimaged pc and still does not work.
Also tried other USB ports.
Next will try uninstalling everything then reinstalling.
(5,991 Views)
