Problem to control AWG
Hi everybody..
i am writing this post cause i'm having some problem to control an AWG from labview; i just need to comand it to generate a linear sine sweep from 1 Hz to 20KHz in 15 seconds; i thing i make the .vi in the right way, but it doesn't works as well.. i post my .vi in 8.5 version.. hope someone could help me..
Thank you in advance!!
P.S: i realized the upper part, the lower part is an exemple from the NI exemple section just to see what signal my AWG is producing..
Nigeltorque
(3,946 Views)
Your example does not look anything like mine. Why are you doing anything with an arbitrary waveform when you want a sine? I don't see anything that enables the output. Strangest of all to me, why are you using the IVI driver instead of the LabVIEW one?
(3,938 Views)
I use the AWG because.. THEY say we have to use it for my project!!; i posted just a part of my project, at last i have to use the AWG to generate:
1) a linear sine sweep from 1 to 20000 HZ with low amplitude
2) a 15 Hz sine with amplitude wich varies from 0.05 to 1 Volt
3) an exponenxial sine sweep from 1 to 20000 Hz (AWG is able to generate just a linear and a logaritmic sweep)
so.. i was thinking about solve to easier case (the first), and then realized the second and the third part..
do you think the .vi i posted is wrong??
Thank you
Nigeltorque
(3,926 Views)
I didn't question your use of the AWG. I questioned your use of that driver for it that you downloaded. Download the LabVIEW Project style driver instead of the IVI one.
(3,922 Views)
Hey Nigeltorque,
The .LLB that you are using in your application is indeed the IVI Driver for this instrument. IVI drivers can be very useful if a customer is interested in having instrument interchangability, state caching, range checking among other standard IVI features (DevZone: Using IVI Drivers in LabVIEW). However, NI's IVI drivers are IVI-C drivers which means that their source code is actually standard ANSI C. You can still easily use these IVI-C drivers in LabVIEW as we provide an API with the installer that calls into the instrument DLL but if you are unfamiliar with C then it might not be easy to modify.
If you are more comfortable with LabVIEW then I would definitely recommend the LabVIEW Plug-and-Play (Project Style) driver that Dennis is alluding to. Here's the link to the driver for your instrument:
Agilent 33XXX Series Signal Generator
If you take a look at this driver, it appears that there is already a frequency sweep example included:
Give this guy a try.
Lars L
NI R&D
(3,906 Views)
