Possible way to use Baud-rate 1Mbps for RS-485 using cRIO?
Hello. I'm using cRIO with RS-485 interface and had hard time translating it to 1 Mbps baud-rate interface.
<Hardware>
- cRIO-9048
- Labview 2020, CompactRIO 21.0, FPGA 20.0
<Problem>
I have used RS-485 port of cRIO-9048 with 115,200 bps baud rate. And would like to change the baud rate to 1Mbps.
As the max. allowable baud rate of cRIO-9048 is 115,200 bps, I bought NI-9871 which is RS-485 C series module with max. baud rate of 3.6864 Mbps.
But it seems although the Max. baud rate of NI-9871 is above 1 Mbps, the allowable baud rate should satisfy the rule below:
BaudRate = 3.6864 Mbps / (Prescaler * Divider)
Prescaler can be (4..65535).
Divider can be 1 or 4.
(https://www.ni.com/pdf/manuals/373170f.pdf)
I tried to use 921,600 bps with 4 divider and 1 prescaler which is closest to 1 Mbps. But the actual baud rate exceed allowable error and cannot communicate with 1 Mbps device.
Is there a way to use 1 Mbps RS-485 interface with cRIO?
(2,264 Views)
Hi snopyy
Did you try to set Actual Band rate (bps) larger value to see if you can achieve your desired value?
Regards
(1,996 Views)
