01-10-2008 02:32 AM - edited 01-10-2008 02:36 AM
01-15-2008 02:44 AM
Hallo Mario,
habe Fluke 289 vorliegen und versucht über LV8.0 anzusprechen. Geht leider nicht.
In der Hoffnung, nicht einem Fehler aufgesessen zu sein, habe ich mal ne Treiberanforderung auf der NI-Seite platziert.
Mal sehen, ob da ein Treiber angepasst wird. Hoffe ich zumindest.
Die alte Version (189) hat funktioniert, ist jedoch nicht mehr ohne Weiteres zu haben. 😞
Die alte Version (Fluke 189) hat mit dem angebotenen fl18x-Treiber unter LV8.0 funktioniert.
Gruß
M.Weber
01-15-2008 02:57 AM
01-15-2008 10:30 AM - edited 01-15-2008 10:32 AM
Hello Mario,
I looked through Fluke's websites worldwide and they don't seem to have a programmer's manual for neither the 287/289 models nor the 187/189 models (which they discontinued after the 287/289 models came out). Therefore I can not say for sure if the fl18x driver will completely work with 287/289 models.
You are welcome to try the driver with the new models however one important thing that you need to do is disable "ID Query" in the Initialize.vi. By disabling ID query, the driver will not check to see what model you are using and terminate the application if a model that isn't supported is connected. Another thing to remember is that the driver will only support the funtionality that is the same as the 187/189 series (assuming that all the commands are kept the same).
You can submit a driver request at http://www.ni.com/idnet so that we can consider it when Fluke publishes their programming interface information.
I hope this information helps. Good luck!
10-12-2009 01:36 PM
Hi Mario,
You can use example fot FLUKE 189.
Just modify something.
Change 9600 to 115200.
Change expected responce from 18x to 28x
Also 289 has much longer RESET time. I added 5 sec delay.
I do not remember all my modifications, but it worked.
Sergiy
