PXI-VISA-MATLAB
Running the following Matlab code:
Visa6541Address = 'PXI17::14::INSTR';
vv=visa('ni',Visa6541Address)
fopen(vv)
reg1 = memread(vv,0,'uint16','PXICFG',3)
fclose(vv)
Results in reg1 = 4243, 28887,6
Where is there a reference to tell me what these number mean please?
 Thanks for any suggestions you can offer!
(3,499 Views)
Hi! Can you give more information on what you are doing? The code alone doesn't tell much.
(3,468 Views)
Accepted by jmreylan
Hello,  Sorry it took me so long to reply.    The code I posted seems too low level to be of much use (unless you happen to be the PXI-6541 designer).   I spent a lot of time trying to control the PXI-6541 through the Matlab Instrument Control Toolbox.  I have concluded that ICT is useless for the PXI-6541 (not generalizing about all NI PXI instruments).  The only way to control the PXI-6541 through Matlab is to write a *.mex file that calls the niHSDIO driver functions.  NI has lots of examples of 'C' programs that do this so all you have to do is convert them to *.mex.   Than you will have a Matlab function that you can call from a *.m file.    You also need Microsoft Visual C installed.
Here is an example of how to compile and link:  mex SPIcontrol.c '-LC:\Program Files (x86)\IVI Foundation\IVI\Lib_x64\msc' -lniHSDIO.lib.  SPIcontrol.c has a mex structure, a little different but well documented at Mathworks.com.  For example, instead of a "main" there is :
/* The gateway function must look like this, don't change names*/
void mexFunction( int nlhs, mxArray *plhs[],
                              int nrhs, mxArray *prhs[])
ViRsrc deviceID = "Dev1"; // NI-MAX assigned this
ViSession generationViSession = VI_NULL; // Not sure why this is called NULL
stat[0] = (double) niHSDIO_InitGenerationSession(deviceID, VI_FALSE, VI_FALSE, VI_NULL, &generationViSession);
and so on....
Finally in your Matlab .m file you have something like:
Emat = SPIcontrol(hex2dec('1234')) % 6541 transmits 1234 on 15 parallel channels out the front panel and returns errors
Maybe this will save some of your readers some time.
(3,450 Views)
