06-23-2008 08:16 AM
06-23-2008 01:03 PM
01-20-2009 06:00 AM
First of all you cannot use RS232 to USB controller to connect your PDA to PLC. to my knowledge there is no RS232 to USB converter with PDA support. You may have to check the ACER website for the cradle with RS232 connector cable. If your PDA has got serial communication support, then generally manufacturer will have a cable with RS232 connector.
Then you can try null modem mehtod for serial communication checking.
