Is the 183617G-01 PCI GPIB card supported by Linux drivers?
I'm trying to find out if 183617G-01 PCI GPIB card is supported under Linux.
Also, I tried searching the NI site for  technical info (specs, user's guide, etc) but turned up nothing for htis card.  Is there a source for such info on this card?  Anything peculiar I should know about this card?
Thanks.
Message 1 of 10
(6,571 Views)
What exactly did you search for? There is the PCI-GPIB product page with links to the documentation and the drivers page lists released and beta versions of NI-488.2 for the supported Linux distributions.
Message 2 of 10
(6,565 Views)
I searched specifically on "183617G-01" and came up with nothing in the way of specific information on this card and its use with Linux, nor any product user guides or specifications.
I do understand that NI has linux drivers, but I want to find out if this specific card is supported.  I did not find anything referencing this card on the links you gave.  Maybe I'm missing something?
Message 3 of 10
(6,558 Views)
You have an older GPIB board with different chips and a different layout but the PCI-GPIB manual and specs should apply to it as well as the latest version. I have not used the older PCI-GPIB boards with linux but used them with everything with a driver for Win98 to a new pc with WinXP.
Message 4 of 10
(6,556 Views)
My experience with Linux tells me it isn't safe extrapolate whether card is supported in Linux by its support in the various flavors of Windows.  I've been burned a few times here.
Anyone have concrete info on Linux support for this card?
Message 5 of 10
(6,540 Views)
Dave_L--
What I did was search on National Instruments' Drivers and Updates page for the NI-488.2 driver, for Linux--the PCI-GPIB uses the NI-488.2 driver.  I found the driver page for the NI-488.2 v2.5 for Linux, which provides a readme.txt link.  In the Readme, there is a section called Supported GPIB Interfaces.  In this section, the PCI-GPIB is listed for Linux support.
I hope this helps.  Cheers!
Tyler C
Message 6 of 10
(6,518 Views)
Thanks Tyler,
This suggests to me that there is a common driver interface for all hardware versions and revisions of the PCI-GPIB cards.
Is that a valid statement?
Message 7 of 10
(6,502 Views)
Dave_L--
If there was a stipulation with any revisions, it would be noted in the Readme.txt.  I'd say this is a safe assumption.
Cheers!
Tyler C
Message 8 of 10
(6,499 Views)
Tyler_C wrote:
Dave_L--
Cheers!
To remove any assumption (even safe ones), I will clarify that this board is supported with our current NI-488.2 drivers for Linux.
-Jason S.
Message 9 of 10
(6,457 Views)
Jason,
Thanks for the definitive answer.
Dave L.
Message 10 of 10
(6,438 Views)
