PCI-8232 GPIB
Hello:
I have an old PCI 8232 Board
I want to know that if the ni 488.2 v2.4 support it ?
And does ni max support it ?
strange is the serial number is 0000000
(2,351 Views)
https://www.ni.com/en-us/support/documentation/supplemental/06/ni-488-2-supported-versions-for-gpib-...
As long as you have a supporting 488.2 driver version and OS, NI MAX will be able to populate it. I was not able to find details about v2.4 to check support for PCI 8232. But looks like all versions above 3.0 supports PCI 8232.
Santhosh
Soliton Technologies
(2,325 Views)
Hi Santhosh:
But the serial number is 0 ,does it means the card  is bad one ?
Best regards
wangl
(2,318 Views)
