OPC Server problems
Hello
I have a question regarding the OPC Server
I have an Aplicom PCI 32k board who make the connection between my MPI network and OPC Server.
In my MPI network I have connected several Siemens PLCs.
Is possible on this OPC Server to receive data from MPI network and receive data for an ethernet card? (I want to connect an Mitsubishi PLC with ethernet ).
Thank you for your prompt reply
(3,741 Views)
I believe you should be able to add it as long as there is a supported driver for the Mitsubishi PLC.
You can find the list of supported Devices and Drivers here.
You would also need to have licensing for that driver.
What version of NI OPC servers are you using?
CLD Certified
(3,723 Views)
The OPC Server version is: Aplicom Server 4.0.15.0
(3,717 Views)
So does that mean you're not using NI OPC servers?
The information I stated above was in regards to using our OPC server software.
CLD Certified
(3,700 Views)
Yes, I m not using NI OPC Server, is Aplicom OPC Server.
I want to apologies for this misunderstanding. I m newbie in this things.
These server was configured by another guy and now I have to connect a new device in this server that are going on Ethernet.
Sorry again. It was my bad.
(3,694 Views)
