No serial COM port available on sbRIO
Dear All,
I use the "Visa Configure Serial Port.vi" from "Instrument I/O->Serial" pallet in my application, to get access to the serial com port on my sbRio-9636.
When running the application the error out from the "Visa Configure Serial Port.vi" states the code -1073807202.
Result by LabView help: "-1073807202: VISA or a code library required by VISA could not be located or loaded. This is usually due to a required driver not being installed on the system."
So I did check out the installed drivers by M&A Explorer and found no NI-VISA drivers installed. I installed the NI-VISA 5.1 from drivers list (Fig1), but still get the same error. Are there further drivers which have to be installed corresponding to COM-Port access by VISA? Currently I only have drivers installed at shown in Fig2.
Thanks in Advance for your help.
ar-numa
(4,198 Views)
Accepted by topic author ar-numa
Hi ar-numa,
Please add NI-Serial RT.  That should resolve your issue.
Cheers,
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(4,188 Views)
Hi Spex,
thanks a lot, your solution solves the problem.
(4,175 Views)
