NI Spy how to delete unnecessary entries
i worked with ni spy to trace an random error and the file become larger and larger. So in the end the trace is unclear and i would like to delete all entries that are not necessary. Is there any possibility with ni spy? What are the advantages of i/o trace?
thanks in advanced
Philipp
(3,071 Views)
Hi Philipp,
that's not possible to do, at least not within NI-Spy. To try it either programmatically (with LabVIEW) or manually, check the following:
"The latest version of Spy, 2.7, contains a LabVIEW API that allows you to start and stop captures. You may get it by installing VISA 4.6
The VIs are under Measurement I/O >> NI Spy.  The LabVIEW API is supported on versions 8.5 and above."
NI-Spy filter
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/NI-Spy-filter/m-p/751540/highlight/true#M3121...
Ni-SPY overrun with data, slowing down system
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Ni-SPY-overrun-with-data-slowing-down-system/...
Jannis
(3,002 Views)
About the I/O Trace:
Why is NI Spy Now Named NI I/O Trace?
http://digital.ni.com/public.nsf/allkb/35FB4F8147512A23862578DF006EEE72
(3,000 Views)
